I have the splash Pack K series pool filter and the motor went. (Splash Pak K Series Pumps Parts - INYOPools.com)It is an A.O. Smith , serial CB03-06, part 7-196192-21, 1.0 HP SPL. Can anyone recommend a replacement model?
Hello TonyNY - We could not cross reference part number 7-196192-21. Could you post a picture of the motor label?
Tony could you post one more picture which is a wide shot showing both the motor and pump housing / strainer basket.ThanksPatrick
Tony,
Thank you for the pictures they were most helpful, you would need this 1 HP Replacement Motor - BN25 When replacing your motor you will also need this Splash Pak Shaft Seal Finally we do have a good Video on How to Replace Pool Pump Motor which you may find helpful as well as Video on How to Replace a Shaft Seal.
