I have a Pentair CF II N1 2A/343240 2 HP pump with a motor number of 168454. It is 220 volts. I think it is a challenger. I would like to know which motor I should buy as a replacement along with whatever seals, etc. are needed to assure that it doesn’t leak when put back together. I am in Texas.
The replacement motor is part number B2858. The shaft seal is part number 5250-104 (5250-210 for salt water). The diffuser o-ring is part number 5002-13A. The main housing o-ring is part number 5002-14.
That should be all you need to get the pump up and running.
