Need impeller
The impeller to my pump is stuck on. A screw broke half way in. Can I purchase an impeller? My motor is a Magnetek part 8-165119-04.
Hello Tomas - The impeller may be available. Magnetek is the brand name of the motor. That motor is used on several pumps. We’ll need to know the make and model of the pump side in order to recommend the impeller. The image below explains the difference between the pump and motor.
Pump
You can send us an image of the complete pump if you are not sure of the make and model.
