I am having trouble finding the exact match to replace this pool pump motor.
My pool pump is a Jandy PHPF Pro Series 1.5hp (newer style - after 2006).
Any assistance will be greatly appreciated!
The replacement motor for your PHPF1.5 is part number B2842. We’d recommend replacing the shaft seal when you replace the motor. The shaft seal for serial numbers before P08FF0001 is part number 5020-086. The shaft seals for serial numbers after P08FF0001 is part number 5020-087.
The serial number you need to look for is on the pump housing. It will not be the serial number on the motor label.
InyoRob, just wanted to say ‘thanks’ for the assistance. This was the correct replacement motor and I’ve successfully replaced the old one along with the shaft seal and life is good again. Can’t wait to jump in soon!,
Thank you for the feedback. We always love to hear success stories. Have a great weekend!
