Need help finding a replacement for my 2 HP Century Centurion Motor: Part 7-193995-07 and seals
We’d be glad to assist you. The replacement motor is model B2843. That motor is used on several pumps. The seals will depend on the pump side. Do you know the make and model of your pump side?
Listed below are the seals for your Jandy Stealth model SHPF1.5.
Shaft Seal - Part Number 5020-086
Backplate Oring - Part Number 5020-136
Diffuser/Impeller Hardware - Part Number 5020-116
Thank you so much!
