Recently got code 172 so interlaced the temp flow sensor to the new one with external box in the middle. Code now reads 145 high salt and that’s a “no way” as water tested shows 2100ppm. Pool store believes it might be the front board. Please help and show me what products to purchase to fix solution. The board shows obsolete ???
Replaced not interlaced above
Hi HalPurdy,
I’m assuming this is a Jandy AquaPure Salt System? I recently had the same issue on my pool.
I first started off by replacing the AquaPure Tri-Sensor and that did not work. Then I went to the front AquaPure Display Board and that did not work. Then I went to the Back Power Board and that was the issue. The connector on the back board was fried (see photo’s below), the unfortunate part was that the cable that plugs into the back board from the AquaPure Transformer was also fried. The AquaPure Transformer cables are only sold as part of the AquaPure Transformer so I replaced both the back power board and the transformer and I was back up and running.
Could you post a few photos of your system so we can make sure to suggest the right parts. Please post the photo’s directly to this Post.
Note: My system is incorporated into the Jandy AquaLink and used the PureLink 6614APL Power Center along with the Fusion Soft Salt System
Hal… I just saw your tag now that says AquaPure 1400 but the photos would still be helpful.
