Can you assist in finding a replacement motor for this one?
Hi Ron, this Booster Pump Replacement Motor - B625 will be a perfect replacement for your booster pump motor. Let us know what the pump model is so we can recommend a new motor shaft seal so it stays leak-free for a long time.
Those pictures are perfect, Ron - thank you! The straight spines on the volute identify that as the Polaris Booster Pump PB4-60 (1994-2011) so we would recommend this Pump Shaft Seal 5/8" - PS-1000 (or the Pump Shaft Seal - Heavy Duty - PS-3865 if you have a saltwater pool) and a new O-ring, Bracket To Volute (258) O-Ring since they tend to get compressed over the years.
For this pump, we recommend putting a small bead of RTV silicone cement on the motor shaft seal and some lubricant on the o-ring. Check out our guide on How To Change The Shaft Seal On A Polaris PB4-60 Booster Pump for some helpful tips.
