A choice for CellType does not come up when pressing diagnostic button 8 times in my Aquarite settings. It goes straight from “r1.4” to the salt level amount. I don’t remember the last time it displayed that option, and it has been working, but now it doesn’t hold the instant salt level, the volts end up at 29.8 and amps goes to 0. The cell was tested out-of-system and DOES produce. About 1 1/2 yrs ago we replaced the Current Limiter - is that bad again? Could that have anything to do with the “missing” setting option to input T-15? And why does the “generating” light stay ON even though it is not producing? Thanks!!
It would automatically default to T15 if the revision is older than 1.5. That would not impact your instant salt reading. The amps reading 0 is a sign of an issue with the board. The current limiter is a possibility. If that doesn’t correct the problem, the board would need to be replaced.
