Here’s a pic of my leaking Pentair valve top. Will the 70 dollar Praher replace this one?
Hello Limey69 - We’ll need to confirm the model of your Pentair filter before we can recommend the correct valve. Do you know the model name of your Pentair filter? Do you have 2" or 1.5" pvc plumbing?
I have a Pentair DNS 48 DE Filter, 2 inch valve.
You could use part number Praher E-50-S2 on your 2" valve for the FNS 48. The E-50-S2 is the top assembly.
Thanks Rob
You’re welcome! Thank you for shopping with Inyo.
Hello Wayne - The spider gasket for your valve would be part number 4600-1104. The gasket can be glued in place using RTV silicone.
