Motor Replacement
We have a Century UST1102 1 horsepower motor that was replaced 2 years ago and needs to be replaced again.
Do you know if th UST1102 2 horsepower or the 1.5 horsepower motor is compatible?
Thank you,
Amanda
Hello Amanda - You could use either one of those motors to replace the UST1102. Are you increasing the HP because you need more flow? A higher HP motor will not last any longer than the UST1102. The likely cause of the UST1102 failure was water damage, an electrical issue, or blocked vents.
