What relacement motor do I need for my motor and what else is required to do the job correctly?
Ser: 08011ch
Part#: 0-193994-06
Type- CX
Frame- Y56Y
HZ- 60
RPM- 3450
VOLTS- 208-230
Ser: 08011ch
Part#: 0-193994-06
Type- CX
Frame- Y56Y
HZ- 60
RPM- 3450
VOLTS- 208-230
Hello Dagerj - The replacement motor is model B2842.
We recommend replacing the seals when you replace the motor. In order to recommend the seals, we’ll need to know the make and model of the pump end.
The pump is a Jandy Stealth
Model- SHPM2.0
SERIAL- T11FF0049
The following seals will get you back up and running. The shaft seal is part number 5020-087. The backplate o-ring is part number 5020-136. The diffuser o-ring is part number 5020-116.
I received the replacement parts. I received 2 diffuser o-rings. Upon disassembly of the old motor/pump I didn’t see but one o-ring. Where does the second one go or is it not needed?
Thank you.
Your pump only requires one diffuser o-ring. For some reason, Jandy includes two in the package.
