Motor Ratings
What is the difference between a Full rated pump/motor and an Uprated pump/motor?
Thanks @Meelowslavich The difference between a Full Rated Motor and an Up Rated motor is the service factor, the service factor will help determine the True HP (THP) of a motor. A full rated motor has a higher service factor meaning that that it is more powerful than the HP in an uprated motor. This is easiest explained through showing the math… below is the comparison of a 1 HP Up Rate Motor Vs. a 1 HP Full Rate Motor.
1 HP Up Rate Motor - 1 HP x 1.1 Service Factor (SF) = 1.1 True HP (THP)
1 HP Full Rate Motor - 1 HP x 1.5 Service Factor (SF) = 1.5 True HP (THP)
In most cases a 1 HP Full Rate would be identical to a 1.5 HP Up Rate. Here is a good article on the Difference between Up Rate and Full Rate Motors which you may find helpful.
Are you trying to size the right pump for your pool? If so could you give the details on your pool like gallon size will you have any water features like waterfalls or a spa? Also what size filter will you be using? If you supply this information then we could help size the right pump for you.
