My pump has gotten quite noisy and I was wondering if you sell I rebuild kit for it. The motor is a centurion 7-168786-07 and the pump is a Pentair Challenger 2HP.
Please advise,
Thank you,
Bob Moline
Please advise,
Thank you,
Bob Moline
Hello Bob - The motor will need to replaced. The correct replacement motor is part number B2843. Does your Challenger model number start with a CH or CF? This number should be somewhere on the housing. That model number will determine the replacement seals.
Thank you for the quick response! I’ll check for the model number when I get home this evening. Is there anyway to replace the bearings in the motor?
Hello Bobmoline - You can replace the bearings. Your motor would require two 203 bearings.
It looks like you have a CH model based on the partial model number (34-520). The tune-up kit would be part number GOKIT5.
