I have variable speed Inteliflo pentair pump,i was running my pump on 3000 and went away for about two hrs.and when i returned i noticed that the water wasn’t flowing and the pump had stopped ,not only did it stop there was no power.so I checked the breaker and the pool light in the pool they were working , put no power to the motor, the light on the keypad was out.no power.has this ever happen to anyone ?
Hi Magoo64,
Did the breaker to the pump trip? Can you measure the incoming voltage to the pump? If so what reading do you get? If you are getting 240V to the pump then it may be that your Intelliflo Variable Speed Drive has gone bad (see image below). Can you send us a few photos of your pump as well as the exact model # of your pump?
