Hello! I need to replace pump motor for waterfall. The motor is A.O. Smith Serial BX3-11; Part 7 -177474-01, Type CX, FR P56Y, ph1, hz60, rpm3450, 230/115 volts, Amps 7.1/14.2, Time: cont, encl DP, form KJM, code J, insul class B, amb 40 c. Unfortunately, there are not numbers for HP and SF on the plate. I believe it is 1.5HP but not 100% sure. Can you help out and also recommend the proper seal kit please? Thank you.
Hello Milorad - We’d be glad to assist you. You could use model number B2853 as the replacement motor.
Your motor is used on several pumps. We’ll need to know the make and model of the pump side in order to recommend the seals. If you are unsure, post a picture of the complete pump.
