I have a Magnum Force Pump that is noisy after sitting this Winter. It pumps fine, but sounds pretty bad. Can I replace the bearings in this pump?
Part Number on the pump says 7-184948-22
Yes, the bearings can be replaced. That motor would require two 6203 bearings.
We’d also recommend replacing the pump seals when you replace the motor bearings. The seal kit is GOKIT14.
