Looking to replace an old unit. This pump is on its own line as a secondary to power 8 spa jets about 25ft away thru 2/1’2 inch pvc brought down to 2 in for pump connections. . Corrosion has eaten thru the motor casing and the wet side plastic is becoming brittle and cracked from South florida sun exposure. I am having trouble identifying which pump this is because the label on the wet end is almost gone. Could you help me find a replacement that will not break the bank lol.
We have a great deal on our PureLine Prime Pumps. We’d recommend model PL2604. This is a single speed 3HP pump with 2" ports.
