I need to know what motor will replace this one.
Also, which variable speed motor can be used as a replacement.
Thanks.
The variable speed replacement for the ST1102 is part number ECM16CU. https://www.inyopools.com/Products/00200017074678.htm
If you know the make and model of the pump side, we can recommend the replacement seals.
