Does the A.O. Smith 1 HP Round Flange Up Rate Motor - UST1102 fit as a replacement for my US Motors 1081 pool motor?
Hi Kevin,
Yes the AO Smith/Century motor does work as a replacement to a US Motors motor. However we would like to get some of the specs. off of your pump to make sure that you have the proper motor selected. Could you give us the following information from the motor label HP, Amps, SF, Volts, FR, Cat #, Mod # Also if you could post a few photos to this thread that would be quite helpful… one wide shot showing the complete pump including where the pipes come in and out and a second close up of the motor label.
Thanks,
Kevin Ross
Hi Patrick,
Have you made a decision on the proper part number for the replacement motor and any other parts needed?
Please let me know?
Thanks,
Kevin Ross
Hi Kevin,
You will need the UST1102 1 HP Replacement Motor and the Jacuzzi Magnum Seal Kit We also have a Video on How to Replace a Pool Pump Motor which may find helpful.
