Hello,
I have an above ground pool by voguepools, about 15 years old, the model is probably Zenith according to the pictures I found (the top caps are these ones but are grey: https://loceypool.com/wp-content/uploads/2019/01/Zenith-Top-Cap-Clay.jpg). It is oval with side supports. The outside dimensions including borders are about 15’ x 26’ (the pool itself is a little smaller, seems a little over 14’ x 25’). The central part is a liitle less wide.The height is 52".
I need to replace the (j-hook) liner. Are your 15’x26’x52" unibead liners suitable for this one?
Thanks in advance,
Tom Keersmaekers
OK, I found out the model of the pool (thanks to your page https://www.inyopools.com/Blog/identify-my-above-ground-pool/ which I didn’t see before): it defintively is a voguepools model zenith.
I removed the old liner so that I could measure accurately.
The pool itself is exactly 15’ x 24’. Height is 52".
Will a 15’x24’x52" liner fit (or is it better to buy a liner which is a little bigger, e.g. 15’x25’x52")?
Can you please confirm this since I want to replace the liner as quick as possible?
Thanks in advance,
Tom Keersmaekers
Yes, you’d want to order a 15’x24’x52" liner. A larger size liner would cause wrinkles in the pool floor.
