Will a slimline 52 inch unibead liner be long enough on the walls on a vogue 52 inch pool installed as a beaded liner
Liner wall height for 52 inch vogue pool using unibead liner for beaded liner is a slimline liner the right wall height
Swimline liner
Hi Hollow92,
Yes, the Swimline 52-inch unibead liner would be the correct liner for a 52-inch Vogue pool using a unibead liner for beaded liner. It sounds like you may be aware of how the unibead liners work but in case you are not then they work as follows… right out the box the unibead liner is a J-hook liner meaning the liner hangs right on the wall of your pool, you can also use the unibead liner as a beaded liner by cutting off the J-hook off which then turns the liner into a beaded liner that clips into a bead receiver.
