We need to replace our pool light. The only info for sure that I have is that the light ring said “Swimquip 5055-11”. I do not know if that’s the actual model number or a part number.
What’s the current model to replace it?
Thank you for contacting Inyo. We’ll need to know the wattage and voltage of the light in order to recommend a replacement fixture.
I was told that I need to replace the entire light. Since we are replacing the whole unit, can’t we just pick a new wattage and voltage?
Yes. Here is a link to our available Swimquip lights https://www.inyopools.com/ProductListing/lights_swimquip.aspx?
So, any of these are the same dimensionas the 5055-11 and will fit the current niche?
Any of those will fit your current niche.
