Good morning, We purchased a pool liner item # LI2148ASO and the liner is not staying in place. The previous liner had grooves or beads around the edges and this particular liner does not which has slipped through the plastic top edge once water was put in the pool. Therefore how do we keep the liner in place without having to use duct tape, which will not look very appealing.
Hello Pool11 - You ordered an overlap liner and your old liner was a beaded liner. The overlap liners require coping strips. These are thin plastic pieces the slip over the liner and hold it in place on the pool wall. A 21’ pool would require 33 coping strips. They are sold in 10 packs. The part number is NL108.
Check out the 3:14 mark in this video.
