I have a Pentair incandescent light fixture that is 300 W and 120 V. The bulb burned out and I was curious about replacing it with a LED color changing light. It looks like the pure line LED light would work for my pool. It’s eight 18 x 22 pool so the 18 W should work but I might use the 35 W for a brighter light. Would these be compatible with my Pentair Amer light fixture?
Hello DennyT - Thank you for contacting Inyo. The Pureline LED bulbs will fit your Pentair pool light. I would recommend the 35w model PL5809. It will have a similar light output to your 300w incandescent light bulb.
We recommend replacing the lens gasket when you replace the bulb. The part number for the gasket is 3525-07.
