Hot Springs Model B. S#. C-286. Yes It is a oldie, but still running on 110V
Replaced the Shaft Seal and still leaks. Would replacing the impeller or Diffuser help. Or is it time for a new pump/motor. PE5D-124. 3/4 hp .
please advise
Replacing the impeller and diffuser would not help the leak. The issue would be the shaft seal, faceplate o-ring, faceplate, or volute. If its not the shaft seal or faceplate o-ring, I would recommend replacing the pump.
