I purchased an Intermatic pool timer model T104R3 from Inyopools last year. This year it has broken and I need a replacement part. The part is WG1573-53 and is the small electric motor and plastic gears that drive the timing set. The cheap plastic gears behind this motor have broken and while the motor runs the not all of the gears turn as the shaft has broke loose from one gear. Can i purchase a replacement motor rather than a whole new unit and if so what is the cost?
Hi JD1958,
I’m sorry to hear that! Yes here is a link to Purchase the WG1573-53 Intermatic Replacement Motor and here is a Guide Showing how to Replace an Intermatic Motor
