I have a very old Jandy Ray-Vac for which i have purchased spare parts from you - Thank you !!
Do you have replacement Ray-Vacs, or other units which work using the same fittings?
At some point I need to purchase a complete new unit, as all the parts are breaking.
I thought you had whole units for sale but I don’t see them on your web site any more, and the cost to buy a new head and a new hose assembly is a lot more together than the entire units were priced at. I am open to switching to a completely different pool cleaner if the Ray-Vac is obsolete now.
Please let me know what you would recommend?
Regards,
Kathryn Reilly
Hello KathrynR - We’d be glad to assist you. We offer the complete Ray-Vac head and the complete hose separately. It does get expensive if you need both. There are a couple different cleaners available that could replace the Jandy Ray-Vac. Both models, like the Ray-Vac, are pressure side cleaners that do not require a booster pump.
The first option is the Polaris 360.
The second option is the The 4 Wheel Pool Cleaner Pressure Model.
We feel comfortable recommending either one. Customers have been satisfied with both models. Hopefully this helps. Thank you again for shopping with INYOpools.com!
Hello KathrynR - Your question was used as the basis for our weekly Poolside Chat show. Hopefully it will help other Jandy Ray-Vac owners. Check it out below.
