HEY WAS WONDERING IF THE GLASS OR PLASTICE SECTION WILL POP OUT OF THE TWIST ON LID AS MINE GOT DROPPED AND CRACKED AND i WOULD LIKE TO POP IT OUT AND jb WELD IT AND THEN PUT IT BACK TOGETHER? CAN i DO THIS OR DOES THE PLASTIC CLEAR PART NOT MADE TO PPOP OUT???
The clear lid can be removed from the lock ring. However, we wouldn’t recommend trying to repair it. If the epoxy does not hold, you run the risk of the crack opening up while the pump is running. The pump would draw air from the lid and cause it to lose prime. A loss of prime will cause the pump to run dry. This could propel the motor to burn up and ruin other pump components.
The replacement lid assembly for the Jandy Stealth SHPF series is part number R0445800. Thank you for shopping with INYOpools.com!
