Jandy lite 2 fuse
Hi,  My fuses blew and i don’t have the type of fuse.  Its the two fuses that lead to the Hot Surface Igniter.  What type of fuse must I order.  I think they are 2 amp 1 1/4 but I do not know if they are 110 volt or more.  Please help.  Thank you.
INYONUNYA,
I believe you would require this Jandy Lite 2 Fuse Assembly listed here.
Thank you.  Would you happen to know what type of fuse is in the assembly. .?
InyoNunya,
I’m checking on this and will post shortly.
Here are the specs. on the fuse… 0.2 amps, 250V.
Thank you.
You’re welcome please let us know how things turn out.
