Jandy gray to never lube
I have the Jandy gray 3 way valves. Pretty sure they are 2" inside and 2.5" outside and would like to change them over to the Neverlube valves. Would it be possible to just change out the inner workings or would I have to change the whole valve. Also if just changing the inner workings is possible is there a plug I can get for the lubrication port on my current valve.
Thanks,
Hello Frank - We do have a conversion kit for your gray Jandy valve. It will convert it to a NeverLube valve. The part number for the Jandy NeverLube Diverter Kit is 4720. It includes the plug for the lubrication port.
Thank you for shopping with Inyo!
Does this kit include any o rings I might need?
Thanks for your help
Frank
The kit includes the two small valve shaft o-rings. The only other o-ring in the valve is cover o-ring, part number 1132.
