Installing Hayward pool heat pump. Need check valve between heater outlet and salt cell. Have Jandy 7236Rev check valves elswhere in system but can’t seem to find same part number on-line. Does anybody know of a source for the 7236REV and would a 7305 be an acceptable valve? All plumbing is 2 inch schedule 40. Pump is two speed Hayward SP3215X202BH (2.4 THP, 2.0 HP, 1.2 ST).
Hello Roaliano - 7236 is the part number of the cover of the check valve. It’s not the part number of the complete valve. The 7305 check valve would be the correct one for 2" plumbing.
Thank you.
You’re welcome. Thank you for shopping with Inyo!
