I have a Jandy Aquapure 1400 and i am getting a 174 code on my display. Is there a way to calibrate my sensor? I have a thermometer in the pool reading 84 degreess but my sensor on my cell is reading 125.
My Jandy PDA is reading 84 degrees as well. I would think the PDA would be getting its results from the “Brains” of the Jandy equipment. Which is why I dont understand the huge disparity between the sensor, PDA and a floating thermometer.
Hi Kris8152,
Most likely this is your AquaPure Tri-Sensor that needs replacing. Here is a good thread on the AquaPure 174 Error Code and few other things you can check before replacing your Tri-Sensor.
If you do determine you need to replace your Tri-Sensor, then we have a Video on How to Replace a Jandy AquaPure Tri-Sensor, which you may find helpful.
