Hello, I have a Jacuzzi MFM17 sand filter and I have to replace the valve assembly. It is a 7 position and it looks like the DVK-7 bolt on type 39262803r should be the replacement. I also need 2 unions for this valve I think they are the 1 1/2" FBT 1/1/2" slip. Does the valve come with the pressure indicator, o ring gasket and glass inspection? Thank you for your info.
The pictures on the InyoPools site for the 39262803R -DVK-7 multi port valve shows that it includes the pressure gauge, sight glass and o-ring.
InyoPools also has the union’s for this valve. The part number is 9175-02
Yes, this 39-2628-03-R Valve is the correct valve for the Jacuzzi MFM17 and it does include the pressure gauge.
