I have a Hayward Jacuzzi light fitting SP-550-L 12v 100 watt with R20 bulb. The cable has failed and I need a replacement fitting that will fit into the existing niche, Can you offer a replacement prefferable LED with 30 foot cable. The housing assembly is SP-505 SP-558 Serial No. is L-614393.
Thanks and best regards, Jeremy
Hi Jeremy,
That light is obsolete without a replacement the only thing you might try is this Spa Light Adapter Ring along with this 12V Color Splash Color Changing LED Spa Light we do not have 100% confirmation that this adapter ring will work with your Hayward Star Lite II series light, however, if you purchase and it does not work then you can return within 30 days in new and unused condition, you would just be responsible for any shipping charges. If you end up going this route then please report back to let us know if worked. Thanks so much!
