This is the picture of the motor tag on my J375 Jacuzzi 2 speed pump that is making noise. What would be the replacement part?
Thank you for contacting Inyo. The closest replacement we have is model BN62. It’s a 3HP 2-speed 230V motor. It will bolt up to your pump housing and work.
Shall I also replace the pump seals? What would be the part number for that?
Does your pump look like the J-Series pump below?
No, I’ll try to post a picture of it soon. The neighbors are beginning to complain about the noise.
Pictures will help. See if you can read any numbers on the plastic parts of the pump.
I finally had some daylight time to take the ph
otos. Unfortunately, I could see no numbers on the plastic parts.Unfortunately, I wasn’t able to identify the pump model. Can you open the pump up and see if there is a part number on the impeller?
