Intake box leaking on the outside wall
Hello, we have an 18X54 in round pool metal walls that we bought from distant relatives that no longer had a use for it. We have setup the pool we replaced the intake box and returns parts that go with our Hayward Pump. We matched the pool parts that we bought on your site to the Hayward Pump we currently have. On the outside of the pool on the wall side of the skimmer box it is leaking water at the bottom part of the rectangle. Its trickling down the wall. We have already replaced the part once so we are not sure what it could be. There is also a small leak dripping from the filter cap onto about where the pressure gage is on the pump. We are at our wits end with this pool, does anyone have any suggestions cause we are new at this and with already replacing the parts we don’t know what else we can do. Thanks so much !
Hi Amanda, we are sorry to hear about that. Did you replace the gaskets for the skimmer when it was reinstalled? And let us know what the model of the filter is so we can help with that as well. Pictures of everything and images of labels with model numbers would be very helpful.
Note that there are a LOT of different skimmers out there, so any part numbers you can get off of any of the skimmer parts would be helpful if you need a gasket for it.
