So, i have what I believe is a pentair intellibrite light in my inground pool. Also, let me add here it’s a vinyl liner. For a few years now we had problems with the unit, like leaks in the light itself. as well as a leak from a crack in the conduit connected to the niche or housing. It’s old, original to pool which came with house when we bought it. It’s not led…2 halogen bulbs with wiring sealed in some sort of clear resin or epoxy? Long story short, my question is, is there a plate or some sort of blank cover they make to completely seal the opening off? We never use the light and figure at least until it’s feasible to buy a new light, I’d rather just seal it off. I’m thinking, some sort of hard plastic that instead of the having the outer ring, that’s screwed in all around, that sandwiches the liner in between the housing. Is there a plate they make that matches the bolt pattern that we can just screw in instead and close off the opening entirely. I’m guessing they have something for this purpose, as I’m sure I’m not the only person who has had this problem, but I can’t seem to find anything. I’d assume I’d have to lower,the pool below the light, remove the screws to remove the ring there now, then hopefully put a cover plate and screw it back together using same screw holes. Is there such a thing?
Forgot to add, electric is all disconnected so no electricity goin to light.
