I recently installed the pool liner lock and it looks and works great. I have a secondary channel just above the liner channel that is slightly larger (photos attached).Is there a product that I can fill in that channel? tThe polo liner lock is too small to hold in it
Hi Paul,
I reached out to our coping manufacturer and below is what they had to say…
Patrick,
I have attached a picture of our CPBL120 and our LTF20.
The larger channel looks like the width of our LTF Liner Track Bead Filler. We usually sell this in 20’ lengths but we can roll it out in longer lengths if needed.
If you decide to do this our part number for 20 feet is: LTF20
It must be indicated on the order is they want a continuous run and not cut at 20’. It would probably be best if the order were sent to my attention just to minimize any errors.
Hope this helps.
Thanks for the info, that looks like it will do the job. I would like to get a 120 foot run and preferably in blue . Can you let me know about color availability and pricing for a 120 foot run
Hi Paul,
The price for the 120’ run would be $299 and this only available in white. Please let me know if you would like me to email you a quote and you can place an order directly through the emailed quote. I will just need your zip code.
Hello Patrick. Please send the e-mail qoute as I will probably order. This is fairly expensive, what is your return policy on this special order product?
My postal code is" N9Y-4G6" in Canada
Hi Paul1045,
I just sent over the emailed quote. If you place an order please let me know as I will need to mark the order as one continuous run of 120’ and not 6 20’ rolls.
