do pop-jets need to be syncronized directionaly for effective cleaning?
In other words should the two or three active jets be pointed in a certian direction. I.E., 9am for all, and then 9 am for the next set of jets and so on.
I guess it also applies to each of the active jets in a group to be pointed in one direction or another.
We’d be glad to assist you. What is the make and model of your cleaning system?
A&A Maufactured, Name label is partially removed but someting like “O_(??)_Clean” i do not see any stamped model#'s on the housing. the internal unit is A&A Manufacturing 540277 6-Port Low Pro Parts Kit [ASIN: B00HEAPGZ8]…if that helps any.
We’ve contacted tech support at A&A Manufacturing. We’ll respond back to this thread as soon as we hear back.
Below is the response from the manufacturer.
The cleaning heads do not have to be synchronized in the same direction. The cleaning heads main purpose is to lift the dirt from the floor and move it closer to the drain so that the debris can be suctioned into the drain.
