I have the standard small pump that came in the pools Packaging and it won’t keep it very clean from the bottom I’m looking for a pump that will go with this type and size of pool that I can use a good vacuum on but I don’t know what to buy for a vacuum and I would like to upgrade from the small pool pump to a backwash pump thats compatible with a Coleman and the size of a pool
For your 24’ pool, we’d recommend the Jacuzzi Laser 19" sand filter and 1HP pump. The model number is 94084958.
Do you have a sloped bottom pool or is the bottom flat? That will determine the type of automatic vacuum we recommend.
