I’m trying to follow the instructions (How To Replace a Sta-Rite Max-E-Pro Pump Impeller - INYOPools.com; I couldn’t find instructions for DuraGlas) to replace a sta rite motor in a DuraGlas pump. After I unscrewed the impeller, the shaft seal is on the motor shaft side (see pic). Do I just lift off the shaft seal using a pair of pliers? And then the copper cone will come out? Excuse the stupid question but I don’t want to break anything.
Thank you for your help!
(This is a follow up to my order of a SQ1052 motor and GOKIT54.)
Thank you for your response. I have now removed both parts of the pump seal. To use the GOKIT54 seal, my understanding is that the copper cone needs to be removed, correct? Do I just pull the cone out from the top with brute force?
Hello Ying - Yes, you can pull out the cone using a pair of pliers. You may be able to loosen it from the back by using a flathead screwdriver and a hammer. Be careful not to chip the plate if you decide to hammer the cone out from the back.
