I have an older gray Jandy 3-way valve that needs lubrication. Grease cup fitting was broken off and epoxied over. Can I take the valve apart and grease using Magic Lube (what to grease?) or just buy/install a new diverter valve assembly. Can I retrofit the gray valve with the newer NeverLube diverter assembly?
Great question! You could remove the diverter assembly and lubricate it manually. The valve is originally lubricated with a product called Water Lube (pictured below).
The other option is to switch the diverter to the NeverLube style. The replacement diverter is part number 25913-204-850.
Thanks for the quick reply. I’ll just replace the diverter assembly with the NeverLube diverter.
