how much to buy
I have the parts for a 27’ x 52" buster crabbe above ground pool. I need a liner, wall foam, groumd pad and cove. Does the replacement liner come with the copping? How much wall foam do I need for a 27’ pool? And I need to replace several of the bottom track pieces. Mine apear to be aluminum. Do you have aluminum stabilizers or just the steal ones? Thank you!
Hello Christina - Overlap liners do not come with coping strips. A 27’ pool would require 44 strips. The coping strips are part number NL108. They are sold in a 10 strip pack. You would need to order a quantity of 5 packs. A 27’ pool would require an 85’ roll of wall foam; part number NL112. We recommend 3 cans of the NL106 foam adhesive to install the wall foam.
Unfortunately we do not carry the bottom tracks for Buster Crabbe pools.
