hot tub o ring
Hello,
i was refered to you by your compititor (hot tub works.com). I have a hot tub Im trying to fix for a friend. i have fixed all the leaks so far, except for the around the motor shaft. I believe i need a O ring kit. my information is limited so i hope you can help me. The hot tub is a california cooperage i believe its a 2003. the model number off the motor is T55MWCBP-1197 1 1/2 hp. mgf # MB01C (frame???) i think it a aqua flow master… what is the likely hood that any of this information is helpful in me finding the correct o ring kit for this hot tub?  and i would like to make a side note that the shaft is a little rusted is that a issue?
Thank you for your time
Brian Jackson
Static1303@gmail.com
Hello Brian - We carry a tune up kit for the Aqua-Flo Flo Master. The part number is GOKIT34. It includes the shaft seals and o-rings.
