I purchased a new Pureline 1.5 HP Above Ground Pool Pump Dual Speed, PL1507 from you about a week ago. It will not accept my current hose from the Pentair Tagelus multiport valve. The hose connector is a female threaded union type approximately 2.375" inside diameter. The original pump was a Sta Rite or Strabright / Pentair pump with an outside threaded diameter of approximately 2.375". The new Pureline pump has a threaded outside diameter of approximately 2.625". Is there an adapter that will fix this?
Hi Jim,
Unfortunately none of the pumps we carry accept that older hose from the Sta-Rite / Pentair Pump. I believe you can go with this Hose Adapter which will screw into the new pump and then you will need this new Pool Filter Hose and this Hose Clamp
