First, please excuse my poor language. French woman in USA need to learn a lot to improve her knowledge.
And about knowledge, let’s explain my problem :
My pool system, built 5 years ago, has never been in trouble. A month ago, I noticed the filtration PSI (before at 13) moves to 25, without any modifications. I used to clean filter at 15 and backwash did nothing. To try to solve the problem, I bought new gauge, then new sand ,then new multiport valve. Nothing happens, same high pressure without any explanations.
PSI are : filtration (25) backwash (12) rince (17). Recirculation position and closed position of the multiport valve have a very bad issue : the pressure is so high that multiport valve becomes stucked.
Am I right with the following :
They are only 4 possible causes of high psi : filter, inlet pipe, inlet nozzles, multiport valve
If in the rince position (so without inlet system) there is still high psi, the inlet pipe and nozzles are not the cause
if sand has been changed and the grinds checked, the filter is not the cause
And if I have already bought a new multiport valve … I have no more cause to my problem.
I can think of one additional possibility. If there has been a check valve installed in the pool plumbing and that valve is malfunctioning or broken, that could cause a spike in filter pressure.
I´ve tried your idea. I’ve got 3 check valves (vacuum, tank, and after the pump) and cleaned them) They seem good.
Checked too the other items in the Inyopool article
In this case it could be a small leak air succion. Where? For me can be only just before the pump because high pressure occurs in all positions (infinity pool, main drain, recirculate, rince) and on all pipe I’ve got valves. I checked with incens not easy because of the air from the pump, checked too with soapy water but cannot find anything
