Had pool resurfaced over a year ago and was fine till a month ago . Pool pressure kept increasing. We cleaned the filter and was okay for about 2 weeks. Then replaced the DE filter grids and was okay for about 2 weeks. I now have it on recircuate but noticed that during this time the DE tank is wet. I did replace the tank gasket over a year ago but could that be the problem…any other ideas???
We’d be glad to assist you. Is the pool water clear?
The gasket is the likely cause if the water is leaking from the tank. You can try lubricating the gasket to see if that stops the leaking.
Click Here to Read More about How to Reduce High Pressure in Your Pool System.
We replaced the tank gasket and lubricatedit but still have the wet looking parts on the tank itself, so what now???
