Hello,
Have a couple of questions about the equipment in my set up.
The attached photo shows the hardware downstream from the pump, fabric filter, and heater.
The Jandy valve at the top of the picture is coming from the heater. The right output is a direct return to the pool.
The other output goes a yellow spherical device and to a second Jandy valve connected to the chlorinator.
Questions:
- What is the yellow spherical device? It has no labels and I haven’t tried to open it yet.
Is there more to it underground? Does it return to the pool underground and why wouldn’t it connect to the main return pipe? - Why would the output of the chlorinator exit to a separate pipe going underground rather than the main return pipe?
Thank you!
