This is a 24’ round hard side pool…the top rail cap number is 11495,top plate is 10134 and looks to be a seaspray high sierra or desert shadow but not 100% sure…im looking for top rail…it measures about 49 7/8 and holes are about 3.5" apart and appears about 6-8" at widest part but could be bent…the closest rail ive found appears to be 18988…do they make a direct replacement or will that rail be closest??
We are sorry to say that the top rails for the High Sierra/Desert Shadow models from Wilbar are no longer available and, according to the manufacturer, there is not another option. Feel free to check out our available top rails. https://www.inyopools.com/parts_above_ground_pool_top_rails.aspx
Some folks have had success using the 21634 top rails, but note that they will need to be trimmed and re-punched to mount them, and you may also need new outer and inner top caps (they would also need to be modified to fit the existing uprights). Full disclosure: none of those items are easy drop-in replacements.
