16x32 oval in ground pool.
Heater or heat pump
What size?
Is it possible diy?
Heater or heat pump
What size?
Is it possible diy?
Hi BasementTrainer,
Could you let us know the following…
Hi
Currently no heater.
Pool only no spa
02190
Nearest city is Boston
Would like to maintain about 80°
Trying to heat the pool and extend into early autumn
Pool depth goes from 3 to 8 ft 16x32 oval
Heater will receive moderate sunlight
Will be using a solar blanket
Thank you
Hi BasementTrainer,
You could go with either a gas pool heater or a pool heat pump. There are Pro’s and Con’s to both systems. The gas heaters are nice as they heat the pool very fast but they are expensive to operate. The heat pump is nice because it costs much less to operate than a gas heater but heats the pool slower, heat pumps use the outside air to heat the water and once the outside air temperature gets to about 50 degrees then the heat pump is inefficient. If you decide to go with a gas heater then I would suggest a 266,000 BTU Raypak Heater and if you decide to go with a heat pump then I would suggest a 125,000 BTU Hayward Heat Pump
